Old 03-03-2017   #1
5ABI VT
Default LT5 Crank to Flywheel bolt pattern ??
Tried looking in the service manuals but no mention of it anywhere. I believe it was different than the LT1 bolt pattern or at least the dowel pin was in a different location etc? Will be pulling the trans and setup out soon but just wanted to ask I have a feeling someone may know !
Thx !
Old 03-04-2017   #2
Default Re: LT5 Crank to Flywheel bolt pattern ??
LT5 has 8 bolts + dowel pin. All others have 6 + dowel pin
Old 03-04-2017   #3
WVZR-1
Thx !
The LT5 flywheel is an 8 bolt affair and you'll not mistake anything in the install. If you've bought a flywheel you should have a 9 hole flange. 8 bolts and the dowel. Less than a 9 bolt flange? You've bought or been shipped the wrong flywheel.
***Jerry was "typing" and I was thinking!!!
Jerry - Not all others are 6 bolt!! I did an LSx 454 which is also an 8 bolt. I did it before specialty flywheels were an "off the shelf" and had to have one done by a specialty shop. I believe that now all LS are 8 bolt '09+ maybe. Then there's the LS9 - 9 bolt!
Old 03-04-2017   #4
Roadster
Roadster's Avatar
1974 LS4 454 Vert
Old 03-04-2017   #5
Tells you how far I get from LT5's these days.
Old 03-06-2017   #6
5ABI VT
Curious if there is a pattern measurement size or something of the sort ? Like for wheels 5x4.75 etc
Old 03-07-2017   #7
WVZR-1
I'm quite comfortable mentioning a 3.0 bolt circle since the LT5 uses an SBC 1-piece rear main so I'd think that remained the same. I have a couple that are boxed but Jerry likely has one on the shelf that's easier to dimension. Tom's is also maybe easier to put his hands on.
I've never seen a bolt circle reference for the 8 bolt LS or the 9 bolt LS9.
Way back in 2010 when I did the LSX-454 it was one of the dimensions I did confirm for the fabrication.
Old 03-07-2017   #8
Roadster
Roadster's Avatar
Mine is not available at the moment, as it is in transit to get machined. Will be glad to take a measurement when it returns if you don't already have it figured out by then...
1974 LS4 454 Vert
Old 09-30-2023   #9
lkeast
I'm planning a 4L60 series auto trans on my 405HP LT5, prob a 70 or 75. Building a restomod 62 on a Dawson chassis with all C4 components. No racing. Need a flexplate to adapt. Pete's ZR1 Garage shows one but is he around? I got no response. I have a machine shop and can easily modify an existing flexplate but which one? Is the 8 bolt LS the same BC and I just add the dowel? What are the 2 small holes at 180 for?
Thanks, Larry lkeast@venturetechnet.com
lkeast is offline   Reply With Quote
Old 09-30-2023   #10
Perry Mitchell
Way back in 2010, I needed a flex plate for my LT5 in a 67 Camaro project I was doing. I was installing a 700R4 transmission behind it. At that time, a company called Street and Performance, which I think still exists, provided me with the flex plate and other parts, such as billet/polished pulleys, polished lower half of the bell housing without a provision for a starter, etc. I heard that Mark, the guy that was working with me, has passed away, but maybe they still have information or parts for your project. Good luck.
Perry Mitchell is offline   Reply With Quote
