07-27-2018 | #1 |
Starting issue
Hey guys - just drove my car home. Turned it off in thr drive way and now it will not start battery is good. Is there something with the the security system / key thst will not ket the xar start ?? Any help wouldbe great.
John |
07-27-2018 | #2 |
Re: Starting issue
Does the starter Solenoid move (is there a click and reduction in voltage by diming lights for example)?
If so.....that no start issue will be intermittent until you recondition the Starter Solenoid points. In Emergencies the Z is very easy to push start by hand in second gear pop clutch with key on.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-27-2018 at 10:38 PM. |
07-27-2018 | #3 |
Re: Starting issue
No starter clicking and lights are all bright.
John |
07-27-2018 | #4 |
Re: Starting issue
Hello,
This has happened to me several times when I first got my ZR1. I realized that each time it happened it was because I was not fully engaging the clutch which prevented it from starting. Part of the security system.
John Glyder ZR-1 NetRegistry Membership Chair [ 1988 Corvette Challenge Car #66 WAZOO Member 1991 ZR-1 #1029 - Sold 1985 Corvette - Sold 2023 BMW X4 |
07-27-2018 | #5 |
Re: Starting issue
Clutch is down to the floor
John |
07-27-2018 | #6 |
Re: Starting issue
When you get in is the security light on the left side of the cluster blinking?
H
07-27-2018 | #7 |
Re: Starting issue
Yes it is.
John |
07-27-2018 | #8 |
Re: Starting issue
Try splicing into the large purple wire in the harness in the back near the firewall . Then touch it to the positive on the battery , see if that spins it over . Make sure its not in gear !
07-27-2018 | #9 |
Re: Starting issue
When your inside and the door is closed does it go off?
H
07-27-2018 | #10 |
Re: Starting issue
In addition, once in the car, door closed, turn the ignition on without attempting to start, does the security light go out after 2 seconds?
H
