Old 05-05-2019   #1
Subfixer
Subfixer's Avatar
Default Busy Day...
Finally got the time to take care of some minor issues...
New Spark plugs - easy
Non-working pass side bolster adjustment - turned out to be bad contacts in the switch. Removed switch, dismantled switch, cleaned contacts, reassembled. Works great.
Non-working Lumbar pumps - Rebuilt both pumps, homemade diaphragms, now work fine.
Non-working LF speaker - Removed, waiting for replacement amp. Will rebuild original at work and keep for a spare.
LED Fog lights - easy once I found out how to access them.
LED Tail lights - easy
LED capable flasher - What a PIA to get to, but done.
Need a solution for LED front parking/turn signal lamps. The ones I got didn't work when parking lights are on.....
Time for a nap......
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 05-05-2019   #2
Default Re: Busy Day...
That one is a little tricky.
Suggest you PM me or -=Jeff=-
Old 05-05-2019   #3
conesare2seconds
Sounds like a productive weekend. Way to go.
