Old 03-28-2007   #1
turboimpala
Default Clutch Master Cylinder Question
I purchased a new clutch master cylinder from NAPA because my original is leaking.
The rod that connects to the clutch pedal is not included in the new cylinder.
Is that normal?
Am I supposed to use the rod from the original cylinder?
turboimpala is offline   Reply With Quote
Old 03-28-2007   #2
Jeffvette
Default Re: Clutch Master Cylinder Question
You need to resue the original rod. There is a snap ring that holds it in place. Place some grease in the pivot hole before inserting the rod in the new master.
