Old 12-14-2020   #1
32valvZ
32valvZ's Avatar
Default Are These the Correct LEDs?
New Osram Chips 110W 5x7 Inch Led Headlights 7x6 Led Sealed Beam Headlamp with High Low Beam H6054 6054 Led Headlight Replacement for Jeep YJ Cherokee XJ H5054 H6054LL 6052 6053 2 Pcs
Sold by: Afex
$85.99
I couldnt find anything for a Corvette application.... Only Jeep!! Is the connection the same for our cars?
Old 12-14-2020   #2
ram_g
Default Re: Are These the Correct LEDs?
This is exactly what I used in my car - they work great and are a huge improvement over the stock lighting pattern/output. I have no regrets whatsoever.
However, be aware of the following:
- The stock sheet metal buckets need to be slightly modified to allow these to fit. Specifically, there is a small "bump" on one side of each bucket, that needs to be trimmed away for these to fit. I used a Dremel tool with a cutting disk and simply cut off the sheet metal in that area. That worked fine and there is plenty of material around the cut to provide strength.
- You will need to modify the foglamp wiring to ensure that the foglamps work. I was not able to make load resistors work with these LEDs. I did the "Yun mod" on the foglamp relay and that worked out perfectly.
- The LED units are quite a bit heavier than the stock plastic headlamps. My headlamp motors (specifically the plastic pellets inside) were already on their last legs and pretty much gave up after I made this mod. Replaced the pellets and all is well again.
Finally, be aware that this unit is available in a black background (as pictured) and also in chrome. I chose chrome as I think it looks better / closer to stock. YMMV.
ram_g is offline   Reply With Quote
Old 12-14-2020   #3
Ccmano
Ditto... if you know what that means.
H
Old 12-14-2020   #4
G8nightman
G8nightman's Avatar
I put them in 3 different cars they fit right in no mods.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 12-14-2020   #5
Locobob
I tried those briefly but wasn't super impressed with the light output. I'm running the Genessi 7x6 and I'm really happy with them, they are closer to $200 for the pair though. And yes the Jeep XJ and Corvette are the same, I own those exact two cars lol
Robert
Old 12-14-2020   #6
32valvZ
32valvZ's Avatar
Thanks everyone... They'll be here Friday. I hate driving my Z at night.... and the wife forget it... she is white knuckling it the whole ride... I figure for $85.00 they're worth a shot over the yellow stockers.
Old 12-14-2020   #7
mpiecyk
Robert,
Do you know the model number of the Genessi 7"X6".
Tanks in Advance
Mike P.
mpiecyk is offline   Reply With Quote
Old 12-14-2020   #8
I have GE Nighthawk LEds for headlights and Beamtech LEDs for Fog lights
Old 12-14-2020   #9
Locobob
Originally Posted by mpiecyk View Post
Robert,
Tanks in Advance
Mike P.
The box says A0102, they are a little difficult to track down, I think I found them on Amazon. I thought I did a write up on them here but perhaps not, I do have a write up with pics on Facebook (Locobobs ZR-1 Page)
Robert
Old 12-14-2020   #10
mpiecyk
Hey Jeff,
Was the installation for the fog lights very difficult?
