Old 03-30-2021   #1
40zr1
Default drain hole
Water stays in the channel of rear window glass, isn't there a rubber drain tube that can be installed by drilling a hole in the corner. Would anyone know of a vendor who sells this? And what's it called?
Thanks
40zr1 is offline   Reply With Quote
Old 03-30-2021   #2
viper107
viper107's Avatar
Default Re: drain hole
Ecklers has been selling them for years
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 03-31-2021   #3
mcich7781
mcich7781's Avatar
Don't do it!!!.
Don't drill holes there!!!
There is a possibility of creating stress cracks in the body in that area. It is not worth the risk.
Spend $4 and get a Baby Nasal Aspirator Bulb and keep it under the seat.
Works perfect takes a minute to suck up the water.
Sent from my SM-G955U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 03-31-2021   #4
40zr1
Thanks for the replies! Gonna play it safe and not drill.
CJ
Old 03-31-2021   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Just swipe your wife's turkey baster out of the kitchen drawer, works great.
She won't miss it till Thanksgiving....
Mystic ZR-1 is online now   Reply With Quote
Old 03-31-2021   #6
Actually, I installed those drain tubes on both of my ZR-1s and they worked fine. No issue of stress cracks but needed a long drill bit. However, on the '95 when I was drilling the hole on the passenger side the lights blinked on and off so I stopped. Later took it to Marc and he said I had drilled into a wiring harness. Fortunately did not do much damage and Marc finished the drilling. I had done the drilling without dismantling any of the interior in the hatch area. I would, in hindsight, recommend you pull back the carpeting so you can see everything when you drill. --Bob
Old 03-31-2021   #7
rush91
Originally Posted by mcich7781 View Post
Don't do it!!!.
That is a BRILLANT idea!! This will replace my old method of using a shammy to soak up that water.
rush91 is offline   Reply With Quote
Old 04-04-2021   #8
Norwegianmopar
Norwegianmopar's Avatar
Our Admiral Blue 94 has the holes and tubes, and it works fine. Our old 91 did not have them, and it felt like a gallon of water each time I towel dried the car after washing it.
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 04-04-2021   #9
I drilled mine to install the drains, 19 years ago and no cracks.
Old 04-04-2021   #10
Young1
Young1's Avatar
Wash, 80 mph air dry, what shammy?
Steve Young
Second Owner
SOLD
SOLD
