![]() Join Date: Jan 2021
I wonder if anyone has similar experiences or an idea... Every now and then when shutting off my engine I hear a rather loud an harsh rattle for a fraction of a second on the very last few revs.
There are no noises when firing her up or during operation (yet I sometimes hear a kind of knocking sound when engaging the clutch after shifting - though it's rather rare). The rattle comes from underneath the car, I'd say clutch / bellhousing area. But I could not spot it any more precisely than that. It sounds a bit like a rattle can when you shake it very fast. Car is an all original 20k mls car, runs and drives smooth and with no noticeable noises or play in the drive train. Could it be a flywheel issue or noises from the gear rings? I'm using synchromesh fluid instead of engine oil in my gearbox.
ZR-1 #638/1991 |
![]() Join Date: Jul 2020
Start up and shut down rattle noise is more often than not tend to be something loose external to the motor. Often a heat shield near the exhaust for example.
![]() Join Date: Nov 2016
Pretty common for a dual mass flywheel.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
Interesting to hear that. Non of my other stick shift dual mass flywheel cars has similar issues. But indeed I heard of it. So, first time for me now I guess...
Is it a first indication of an upcoming breakdown or just something that happens? By the way - how much does an OEM flywheel of a ZR-1 weight?
ZR-1 #638/1991 |
Combination cam chains/flywheel. My 91 #634 does it.
#6 | |
![]() Join Date: Dec 2003
37.25lbs
