Old 05-17-2022   #1
Matt B
Matt B's Avatar
Default Differential fill plug tool size
Stupid question, but what would be the correct tool to remove the differential fill plug? I tried 8 and 10 mm metric allen wrenches but neither really fits.
Is it an imperial size? Or just super uncommon 9mm? Thanks!
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 05-17-2022   #2
HAWAIIZR-1's Avatar
I could not remember what I bought, but I have a long hex just for this purpose. It might be a 9mm as Chris states in this video. Someone mentioned a 3/8 hex is it and I am guessing it might be what I have. 9mm does not sound familiar and why the heck would GM use metric, but we have a mishmash bag of metric and SAE all over the car.
https://youtu.be/HOp67Cr2BNs
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-17-2022   #3
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Differential fill plug tool size
The plug in mine takes a 3/8" hex wrench.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-17-2022   #4
Just in case when you are under the Differential, you can add another "Removable Plug"
Just to make sure you have clean Differential Oil
Post 147 - ZR1 Added Systems including Differential Case Drain
Old 05-18-2022   #5
leusgs
It's a 9mm - uncommon size but available (Lisle #33960).
3/8 works out to 9.5mm - doubtful to fit.
leusgs is offline   Reply With Quote
Old 05-18-2022   #6
Jagdpanzer
Jagdpanzer's Avatar
The rear differential is produced not by GM but by Dana Spicer. I've rebuilt a number of these and every component in it, including the bolts and fill plug, are based on imperial dimensions. Here is a photo of a 3/8" hex socket fitted in the fill plug. IMG_2896.JPG
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-19-2022   #7
WVZR-1
The rear differential is produced not by GM but by Dana Spicer. I've rebuilt a number of these and every component in it, including the bolts and fill plug, are based on imperial dimensions. Here is a photo of a 3/8" hex socket fitted in the fill plug. Attachment 17709
This is 'For Sure' correct information.
Old 05-21-2022   #8
Matt B
Matt B's Avatar
Thanks for the answers. Tough cookie to get that size over here. Wish I'd known already ahead of the gathering
ZR-1 #638/1991
