![]() Join Date: Oct 2022
Hi everyone. I'm new to the registry after buying a 91 ZR-1 last May. My fourth Corvette. I bought it from the original owner's family who stated the tires had been replaced October 2021. It had 9650 miles at the time (just about to turn 11k now). When I got it, I noticed a strange sound like a rock rolling around in a can coming from the right front at slow speeds. My local Corvette specialist, helped me determine that it was the tire pressure sensor INSIDE the tire. The tire shop took it off the rim and found hundreds of pieces inside. After a thorough cleaning, it only took about 5 miles driving to see the service LTPWS light come on in the message center. It resets each time I turn the car off but after about the same distance, it comes back on. I found a replacement on ebay correctly coded for the right front. Now I'm wondering, is there maintenance involved with the sensors? Batteries to replace? The replacement sensor looks brand new but I'm not finding a battery compartment. Maybe the better idea is to remove the remaining 3 sensors, ignore the light, or take the bulb out of that location. I would appreciate your technical expertise and opinions.
![]() Join Date: May 2018
I have a 91 with 84000 miles. The sensors and system was intact and working when I got the car.
I had the sensors and bulb removed when the new tires were installed. They are now in a Costco tote in my basement. I did this because some sensors have come apart and damaged the inside of the tire. This car is a driver and the next owner may do things differently. I have owned a ZR-1 since 2018, others with more experience may have a better solution based on the low miles and intended usage. |
![]() Join Date: Aug 2006
LTPWS sensors in the tire/wheel uses piezoelectric to generate electric charge. I removed mine about 10 years ago when I went to 18? wheels and removed the light bulb behind the warning screen.
With age, plastic has tendency to get brittle and even new might fall apart inside the wheel. |
#4 | |
![]() ![]() ![]() Join Date: May 2007
Either way you have three choices... pull all the sensors, then pull the bulb from the DIC or resort to a piece of black tape over the LTPWS light. Or just replace the sensor and that would be my call on a 11k mile car. ![]()
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-30-2023 at 01:42 AM. |
![]() Join Date: Dec 2007
I have a few sensor forsale let me know if you are interested.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
![]() Join Date: Oct 2017
On a '90, you can remove all the sensors and the light will not come on. '91 and up you will need to remove the bulb.
I removed the sensors on my '90 even though they were working. Didn't want to take a chance on one of the sensors coming apart in the tire. ![]()
Kenny 1990 #442 ![]() |
Some 91s you can remove them and the light will stay off. That the experience I had with my 91.
![]() Join Date: Jan 2021
What about wrapping then in plastic to prevent crumbling?
Thought about wrapping mine and re-install them to maintain the system in working order (as it's SO cool to have a working LTPWS in a 32 years old car)
ZR-1 #638/1991 |
#9 |
My guess is the failure starts at the plastic loop where the stainless steel strap passes through. If you reinforce the plastic loop somehow, might stay on.
#10 |
Concur that's where they all fail
