Old 04-03-2023   #1
Subfixer
Subfixer's Avatar
Default Wipers FYI
I ordered new wipers from Rock Auto. The listing was Trico 600202.
I received NAPA 60-020-2. They are a perfect fit.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 04-03-2023   #2
Mikey
Default Re: Wipers FYI
That's a good bit of info to know. Thanks for posting.
Matt B - you mentioned in another thread you got some from Rock Auto that did not fit - what was that p/n?
Mikey is offline   Reply With Quote
Old 04-04-2023   #3
Matt B
Matt B's Avatar
I think it was ACDelco 82191. They're too high and get stuck under the hood.
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 04-04-2023   #4
Thomas ZR-1
Thomas ZR-1's Avatar
I allways recommend the ANCO 14-series conventional windshield wiper blades (metal frame) for the C4... 19" or 20" long. They are very slim and fit perfect under the hood.
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 04-05-2023   #5
1977CamaroZ28
1977CamaroZ28's Avatar
I've been using NAPA 60-020-2 for years and the fit is perfect for our car hoods.
1.990 Chevrolet Corvette ZR-1
#2342 - Black/Black - March 1.990 -
OBX Headers and OBX complete Exhaust Line (No Cats).
K&N Air Filter with open Air Box.
Jerry's Gaskets Silicone Air Duct.
DeWitts Two Row Pro Series Radiator.
Samco's Hose Coolant Kit.
ECM/EPROM Improved.
MSD Spark Plug Wires 8,5mm Super Conductor.
EBC Brakes YellowStuff with EBC D-Series Rotors and Raybestos hoses.
1977CamaroZ28 is offline   Reply With Quote
Old 05-25-2023   #6
Matt B
Matt B's Avatar
FYI: I ordere a set of ANCO9719 (97-19) from Rockauto. These are exactly the same as those branded as ACDelco. No visible differences and, more important, same fit.
Can it be that there are differences across the hoods GM built or maybe an alignment issue hood<->windshield?
ZR-1 #638/1991
Old 05-25-2023   #7
Mikey
C4 hood alignment was a major issue from the factory. Look at any number of C4's and you will see a lot of variation in the quality of the alignment. Most noticeable along the front edge of the hood versus the nose fascia. Not too sure about the fore/aft variance, but the left/right variance is pretty bad. I took the time to center mine.
Old 05-25-2023   #8
Young1
Young1's Avatar
FYI. Later C4 changed to s smaller diameter pin on the wiper arm. Not sure the year. N? size does not fit all.
Steve Young
Second Owner
SOLD
SOLD
Old 05-25-2023   #9
Wouldn't it be best to use original blade holders and put new refills in?
Old 05-25-2023   #10
TX '90 ZR1
TX '90 ZR1's Avatar
This would be the best situation I would think. Trouble is, a lot of the cars have had the original holders removed at blade replacement.
Took me a long time to find an original set of holders for my '90.
Kenny
1990 #442
