Old 06-18-2023   #1
Hobbes
Default What else during header install?
My header install kit from Marc will be here in a few weeks. What else should I consider doing while I have things torn apart for the install? Fuel filter is on the list already.
1991 ZR-1 Dark Red Metallic/Black #1648 Stainless Works headers, OBX cat-back, Haibeck chip, Haibeck 170 degree thermostat, throttle body coolant bypass, led headlights & fog lights, Etoile 455 3-piece wheels.
1973 Stingray Black/Black #421. ZZ4 with Holley Sniper EFI, Tremec TKO-600 5 speed, 3-row aluminum radiator, 18? Foose legend wheels, + lots more.
Hobbes is offline   Reply With Quote
Old 06-19-2023   #2
Default Re: What else during headed install?
How about a thorough cleaning of the engine compartment while you have a little more room in there. When Marc had my '95's engine out, he spent two hours cleaning the engine compartment and it never looked better. Lots of nooks and crannies that you can get to with everything in place. Even if your engine isn't out, losing the headers give you some opportunity to clean better than usual. --Bob
Old 06-19-2023   #3
Hobbes
Good call Bob! I pulled the wheels a few weeks ago and cleaned up all the suspension & brake bits. Will definitely do a more thorough cleaning with the fender liners and manifolds out of the way.
