Old 04-06-2024   #1
BlackroseZ
Default Code 12 Issue
If I've learned correctly the cycling of code 12 means there's no codes to report however I still have a abs and asr light. I recently changed my cam position sensor and my brake position sensor on the master cylinder. What am I forgetting? That's not much to go off but any clues who be appreciated
BlackroseZ is offline   Reply With Quote
Old 04-15-2024   #2
G8nightman
G8nightman's Avatar
Default Re: Code 12 Issue
check your level on brake fluid even if it looks full add some.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 04-16-2024   #3
Code 12 is an ECM self test. ABS and ASR codes are from CCM.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-17-2024   #4
secondchance
Not knowing what year, I can't tell whether you have 12 pin or 16 pin ALDL connector.
Below article should help with your diagnosing the problem.
I can't immagine cam position sensor being related but wheel speed sensor replacement may be related.
https://tech.corvettecentral.com/201...trouble-codes/
