Old 05-11-2024   #1
Raykahn
Raykahn's Avatar
Default reading O2 sensor from Tech1 - AFR concerns
I have a wideband gauge that recently started show me running incredibly lean on medium to hard acceleration (20+ AFR).
Nothing feels off though. If it weren't for that gauge I would have no idea. No codes pop up, no stumble, no roughness.
I borrowed Jagpanzer's tech1 and have been looking at the mV readings from the O2 sensors. At WOT both R and L sensors jump to 800+ mV. My understanding of these sensors is that you can't use the mV reading to determine a specific AFR, but in general being 500+ mV at WOT should indicate I am at least not running lean. That makes me think the sensor for my AFR gauge is bad, or the gauge itself.
Do I have anything wrong here?
How closely should the R and L sensor mV read to each other? They seem to wander a fair bit from each other at idle and easy cruising, but at WOT they both spike and are within ~50mV to each other. At idle the L sensor seems much less stable than the R sensor.
Raykahn is offline   Reply With Quote
Old 05-11-2024   #2
scorp508
Default Re: reading O2 sensor from Tech1 - AFR concerns
Does your wide band sensor have a fresh air calibration routine you can run on it?
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
Old 05-11-2024   #3
Raykahn
Raykahn's Avatar
That is a good question. I'll need to dig out the manual for it.
Old 05-11-2024   #4
Raykahn
Raykahn's Avatar
There is, but I need to access a controller box that was buried away during installation. I'll have to dig that out to initiate the recalibration, and relocate the box for future ease of access.
Old 05-12-2024   #5
Not unusual to have a rich/lean disparity between banks in idle state w drivers side being lean.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
