Old 04-16-2025   #1
Jetjock
Jetjock's Avatar
Default Looking for Oxygen sensors for my engine
I was having problems with my 93 ZR-1 and I pulled the codes and it turns out to be the O2 sensors. What does anyone use for O2 sensors? Thanks.
Roy
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
Jetjock is offline   Reply With Quote
Old 04-16-2025   #2
Starman
Starman's Avatar
Default Re: Looking for Oxygen sensors for my engine
My preference is the Bosch like the originals. As I have headers I did upgrade to the externally grounded type, one more wire than stock, going to frame.
Starman is offline   Reply With Quote
Old 04-16-2025   #3
This is old data but interesting
Replacing O2 sensors
O2 sensor with SW headers
Old 04-16-2025   #4
Young1
Young1's Avatar
I installed Bosch 13077 45k mikes ago. Solved all the codes then. 21 dollars each on Amazon.
Steve Young
Second Owner
SOLD
SOLD
Old 04-16-2025   #5
I am using NGK/NTK 21003 with no issues
Old 04-17-2025   #6
Jagdpanzer
Jagdpanzer's Avatar
Also use the NTK 21003 O2 sensors with good results.
Their pigtails are longer which works better with headers.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-17-2025   #7
Jagdpanzer
Jagdpanzer's Avatar
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-18-2025   #8
I use AC/Delco O2s when I can find them. Haven?t tried Denso and have found that Bosch O2s have a tendency to drop signal intermittently resulting in ECM using Open Loop at times.
Old 04-18-2025   #9
Jetjock
Jetjock's Avatar
Thank you for the responses. I contacted Marc Haibeck and he told me to get Bosch 13077 sensors for my LT5. Just waiting for a time to install then and see how that works. I suspect that these are the original sensors since they have the short pigtails. Thank you.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 04-19-2025   #10
tiegsd
tiegsd's Avatar
About to install Denso sensors, we'll see how it goes.
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
