Old 07-14-2008   #1
xxxscimitarxxx
Default First days driving depression
Hi to All
well my 90 ZR1 arrived in UK a couple of weeks ago and l went to collect....
typically with any car going US to UK the battery was dead, meaning deceased...this happens even if the battery is new as shipping handlers find mysterious ways to kill batteries in transit
we got him jump started tho and all was well, though didnt stop the engine for the whole 120 mile trip back
the drive was faultless tho nowhere to stretch his legs as this is UK and even freeways at mid day are like rush hour.....what was noted was how lazy the LT5 is .....bout 70mph and 1700 rpm in 6th.....casually overtake anything in 5th....really overtake anything in 4th....totally blow them away in 3rd
couple of faults ....LTPWS....ok no real worries ...old tyres....need replacing
service ride control came on
Ok l will sort that out....but Q.....can you change ride settings while on the move....or did l screw it up by doing so
So......happily got home...stopped car....would not turn over when tried to restart.....
took battery off and put on charger.....got hot....sides of battery expanded.....messy looking cells......so got another battery....but had to leave abroad before it arrived so left son to fit it
called him and he said it wouldnt start
Ok he didnt know about the cute US car trick of needing to put foot down on clutch
now l dont know if hes been back to try again.....lm hoping that was all it was.....maybe know today.....but with my luck that wont be it
so as he left it....all the gauges light up but no turn over...not even a click
So.....could someone help me with a dummys top 10 guide to "it wont start" issues......starting with dummest and finishing with not so dum
my sons bright but 16 and looking at a car that hes never worked on before
HELP
xxxscimitarxxx is offline   Reply With Quote
Old 07-14-2008   #2
Default Re: First days driving depression
I know we have a few threads on the dreaded "no-start" here and over at the net registry site in the maintenance section....I believe "common issues" and "how to" ...I think if I remember correctly.
However, welcome on the new toy!
If the clutch pedal was not depressed the starter will not activate, but the DIC will light up all the lights. That is probably all that was preventing the start up, provided the replacement battery was the correct CCA rating and fully charged. I can't see what could have gone wrong from jumping her to give any issues at subsequent start-up's....hopefully it is just that the clutch pedal needs to be down for a start-up.
Old 07-14-2008   #3
xxxscimitarxxx
Thanks for that....lm hoping clutch down is all it is.....will call today and find out
dont think it can be starter, as it managed to jump when l collected it. Dont know where the clutch switch is yet or how to by pass it if its that fault. Dont think it could fail between collecting it and failing to start, but you never know
Old 07-14-2008   #4
jonszr1
jonszr1's Avatar
did you get a factory service manual with the car? if not i would get one , they sure help finding the problems and answers . you can use the searxh here for threads to help also . no worries its proably something simple.
Old 07-14-2008   #5
xxxscimitarxxx
yep...l got the all manuals before l even got the car but l will need to take a week off work to read them....hoping its easy as you say....one thing seems for sure is that you can spend as much time reading about ZR1 maintenace and repairs as you can driving them....probably more
Old 07-14-2008   #6
jonszr1
jonszr1's Avatar
i wish i was good enough on these things to be able to post a link for you. one way to tell if your clutch switch is working is turn it to start and watch the volts gauge as you push the clutch in and out if there is no change then bingo thats the offending angel. hope this helps a little
Old 07-14-2008   #7
RICHARD TILL
XXXSCIMITARXXX, You CAN change the ride settings while on the move. Does`nt hurt a thing.
Old 07-15-2008   #8
Congratz on the Z!!
As for "service ride control"... I'll see why mine came on for the first time ever, and we'll compare notes. It's prolly a connection or some such simple thing (I hope!). However, you can switch between modes "on the fly" - really cool feature!!
Welcome to the club! When ya get some time, how 'bout some pics of your new toy with some of that English countryside in the background??
P.
Old 07-15-2008   #9
ZR1Vette
ZR1Vette's Avatar
Another welcome to the world of ZR-1s... really special cars!
Since we are trouble shooting... could also be the battery connections...if cables are a bit loose indicator lights can light up but not sufficient for the amp draw down when trying to start... also does your car have one of those battery cable quick disconnects... those things can be trouble from the get go
Hope whatever is the issue it is easily corrected
Old 07-16-2008   #10
xxxscimitarxxx
Thanks again for responses guys
verdict still out as my son hasnt tried to start it yet....too busy chasing skirt and on line chats
will definately post the cause of ride control service light when l find it
will have a photoshoot of the back roads in Essex next time lm back......l really wish l had a job in the UK....I get to drive my cars a few hours every few months ....but l know they are there.
