Old 08-09-2008   #1
WydGlydJim
WydGlydJim's Avatar
Default Injector removal question
How do the injectors come loose from the injector housing?
Thanks.
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 08-09-2008   #2
Polo-1
Default Re: Injector removal question
2 10mm bolts. pull the fuel rail up.
Old 08-09-2008   #3
Ccmano
Once the screws are removed and the fuel line is disconnected you simply lift the whole assembly up and off. There is nothing holding the individual injectors into the housings other than the o-rings. Keep in mind they have been in there 18 years or so and will probably need some extra leverage to get started. I used a wooden hammer handle to pry the assembly off.
Good luck,
Hans
Old 08-09-2008   #4
WydGlydJim
WydGlydJim's Avatar
Good luck,
Hans
Thanks having never done it before, just didn't want to get too tuff with it, before I knew the only thing holding them in was the o-rings.
2009 LS9
1973 LS4/sold
Old 08-09-2008   #5
Its a little easier to work form the front and move to the back on the fuel rail.Work it a little,get it to move and them move back some and work it lose.
Old 08-09-2008   #6
32valvZ
32valvZ's Avatar
Also, no need to remove the fuel line. You can just lay both rails upside down on a towel on the windshield. I pulled all 16 out & installed all 16 like this.
Old 08-09-2008   #7
Jeffvette
Just to add, for more information overload....
Squirt a little wd-40 or a penetrating lube down by the injectors to help with removal. If they are really stuck, you run the risk of having the injector pop out and fuel going everywhere.
You can do the replacement with the lines still attached, but you have better control on a work bench.
Old 08-10-2008   #8
I know that this is a bit rediculous, but if you have one of those Clubs....the end without the lock mechanism works perfectly as the "U" end fits the rail like it was made for it....stick it near an injector and lever against the I/H / cam cover....the rubber coating protects against any paint/powder coat marring....I doubled up a M/F towel & laid it along the cam cover for added protection.
Old 08-12-2008   #9
Zr1 Destroyer
Zr1 Destroyer's Avatar
Yes...then bring them in an air conditioned house and do the swap on your wifes dining room table!!!
Zr1 Destroyer is offline   Reply With Quote
Old 08-12-2008   #10
Polo-1
and now that the easy part is done, you can start doing this.
