Old 08-10-2008   #1
WydGlydJim
WydGlydJim's Avatar
Default Power steering pump removal question
Is the first step to get the pully off? How is this accomplished. The pump removal doesn't look very straight forward, and the manual is confusing, and unclear as to the steps. I need to remove to get the cam cover off. Any tip sheets out there?
Thanks in advance.
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 08-10-2008   #2
Jeffvette
Default Re: Power steering pump removal question
Jim, follow along
http://www.pnwzr1.net/LT5_tear_down.htm
Power steering unit is in part 2. But it's held on by three bolts.
Old 08-10-2008   #3
WydGlydJim
WydGlydJim's Avatar
Originally Posted by Jeffvette
Jim, follow along
I wasn't clear on where this stuff was last night.......thanks I think I'm going to take a break!
2009 LS9
1973 LS4/sold
Old 08-11-2008   #4
tf95ZR1
tf95ZR1's Avatar
Basically the PS pump pulley has holes in it.
Turn the pulley to line up the 3 bolts one at a time.
Old 08-11-2008   #5
Actually...There are more than 3 bolts one can remove from the access holes in the pulley. (Don't ask!) Only the three long bolts hold the pump on, and the others hold the reservoir in place.
The pump removal was easy enough, but it was the fluid change out that was more of a challenge than anything. It can get messy - or did for me. All-in-all tho, it wasn't a bad job. (Beats the hell outta changing the Opti on an LT1 car, I can tell ya!)
There is a groove around the hub of the pulley. You'll need a puller to get the pulley off, and that groove is the purchase point for the puller. (I got a puller at Napa that worked very well.) Pay attention to getting the pulley reinstalled so that it lines up with the other pulleys - don't want any angle or offset as the belt will not be happy if there is.
Good luck!
P.
