Old 08-17-2008   #1
Default IH gasket coolant leak w Pics
For the past several weeks I was noticing a bit of white smoke coming from the exhaust. It went away once the motor was warmed up and I had
attributed it to the new MagnaFlow I had installed. But there was a bit of a coolant smell tho. However, I did a WOT run and then the smoke really came out. SO, off came the plenum. =Jeff= and I did a coolant pressure test as recommended by Ccmano and karterdon, and we saw coolant dropping into the #4 primary runner coming from between the cylinder head and the IH. I had used .030" gaskets when I did the P&P this winter.
I think that's too thin to hold up. Now replaced with .060" from FlatOut Racing. Motor runs much stronger when firing 8 cylinders.
While I was at it I blocked off coolant passages at the IH/Plenum interface
Pics below:
Old 08-17-2008   #2
lbszr
lbszr's Avatar
Default Re: IH gasket coolant leak w Pics
Good to know! Mine has had the same gasket from FO since March with no trouble. Installed mine dry this time.
The ones I've taken apart seem the bolts could use a retorque. Was planning on checking torque of the IH this fall.
Old 08-17-2008   #3
Aurora40
Aurora40's Avatar
Any pictures of that? What did you do to block it off?
Was the I/H to head gasket a GM one?
Old 08-17-2008   #4
Bob,
He might be talking about HOTB Issue #10, Apr 07 that Locobob wrote. Great article and I followed step by step to do mine too.
Old 09-01-2008   #5
Originally Posted by HAWAIIZR-1
Bob,
These damn guys from Hawaii..... Showoff!!!!!
Wow that is what a Z motor should look like, PERFECTO!!!!!!!
Old 09-01-2008   #6
Hawaii:
http://www.youtube.com/watch?v=fK6jJaHf80M
92 ZR1
#234
Old 09-01-2008   #7
Yep it is almost too sanitary!!
We all need our LT-5's to look that pretty
Old 09-01-2008   #8
Jagdpanzer
Jagdpanzer's Avatar
Bob,
HAWAIIZR
Great looking engine!
Can you give us the details on the paint finish?
What silver did you use?
Old 08-17-2008   #9
Bob,
Sorry didn't take pics, but its the IH coolant passage that mates with the plenum passage to the TB. Found on either side between primary #4 and secondary #2, primary #3 and secondary #1 runners. I used a 1/8 NPT countersink socket head plug. Drilled out existing hole with 21/64" bit, then tapped with 1/8 NPT tap. Got all at ACE hardware. I put a bleeder valve on the passenger side coolant tube using the same bit and tap.
The I/H gasket I used were from Flatout Racing. Only this time I used a .060" rather than a .030".
Old 08-17-2008   #10
Toyvet1
How come whenever something odd happens -=jeff=- name is always close at hand??????
Toyvet1 is offline   Reply With Quote
