Old 02-12-2012   #25
Corbusa
Default Re: Dyno Pull yesterday (OBX Headers)
Ok as far as heat - would it not help if the water pump was ported in some way ( to create more flow)? what about using waterwetter ? Are there any part numbers for a higher flow radiator?
I too used to cut the spring (center) out of my thermostats and just use it as a restrictor to help slow the water down a little... it always helped..
