Old 02-25-2013   #1
mgbrv8
Default Plenum Pull Advice, Starter Rebuild, MAP Sensor Info
Okay I have finally gotten back in the states and have some time. I am going to pull my Plenum on my 91 Z this weekend so I can rebuild my starter. Is there anything else I need to attend to While I'm in there. All advice and links are welcome about anything My car has 88,000 miles on it.
Dave
Old 02-25-2013   #2
zr1mom
zr1mom's Avatar
Default Re: Plenum pull advice
Look for brittle vacuum hoses, lose connections, oil and dirt in the valley. Check the drain hole is clear.
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 02-25-2013   #3
In general like ZR1mom suggests
Compressed Air works great from below on the valley drain tube just to the rear of the oil pan on passenger side.
Now........get ready for some fun
Oh......drain some coolant first so when you remove the plenum the Throttle Body (TB) coolant is not getting into the Injector Housing. Or....here we go.....
Block the TB coolant when you are there
LT5 Eliminated Systems
Old 02-26-2013   #4
jimmy b.
jimmy b.'s Avatar
check the crankcase breather hoses and especially the clamps mine were loose and letting oil leak out of them, also the vent cover bolts,gasket,etc,etc.
jimmy b. is offline   Reply With Quote
Old 02-26-2013   #5
remove that pesky additional aluminum from the runners if you have not already
LGAFF is online now   Reply With Quote
Old 02-27-2013   #6
mgbrv8
How much coolant should I drain for a upper plenum pull??
Dave
Old 02-27-2013   #7
mgbrv8
I removed one and a eighth gallons by tapping into the line that goes to the radiator from the coolant resevior like is depicted below is this sufficient for a upper plenum pull?
Dave
Old 02-27-2013   #8
Dave
I would think that would be close......you want to get below the top of the IH coolant manifolds. You want to have a couple of Jerry's Plenum gaskets on hand also. I just drain coolant out of the radiator petcock on lower passenger side of radiator. I also have on hand a gallon of NAPA antifreeze to replenish the coolant. Or a good time to flush the coolant system and replace coolant.
PLENUM
Plenum pull TIPS
Plenum Removal Simplified TIPS
LT5 IH, Fuel Rails, Plenum Install Tricks
Plenum pull questons
Plenum pull tools and parts
Plenum pull parts
Under the plenum
Plenum bolts install
Porting
Plenum & Cam cover restored pictures
Plenum gasket drawing
Ebay ZR1 LT5 Plenum
Old 02-27-2013   #9
mgbrv8
it looks like my a/c compressor is leaking and its a little oily on the vent box and looks like some one did a little mild porting in the past, what do you all think any observations or suggestions??
Old 02-27-2013   #10
If you are referring to the cresent shaped cuts in the IH to head surface that is factory matching, not porting done later.
PORT IT!!!
