Old 05-13-2013   #1
Schrade
Default Help; where's this post by Marc H???
In an exhaust / header discussion thread, Marc H posted (or someone quoted him from elsewhere) , where the 'bottleneck' is in stock exhaust '90.
Anybody remember it?
I need to know if it's a factor in a potential header purchase @ BG...
Thanks here...
Old 05-13-2013   #2
Default Re: Help; where's this post by Marc H???
resonator I beleive
Old 05-13-2013   #3
Schrade
Thanks there Sir; now - is this a factor of any sort in header purchase?
Old 05-13-2013   #4
efnfast
Check this from Marc's site
http://www.zr1specialist.com/HAT%20W...rly%20Cars.pdf
Old 05-13-2013   #5
Schrade
Originally Posted by efnfast View Post
Thanks
Apparently it's not a factor; rather a separate consideration:
Originally Posted by thethrillofspeed View Post
Does it replace the factory resonator?
Originally Posted by gbmidyear66 View Post
Headers just replace the factory exhaust manifolds and factory CATS
SW also sells a seperate exhaust system I believe - you could use factory, use the SW exhaust, or some other aftermarket exhaust system
Only if you also opt for the X-pipe too. Which reminds me...
If I recall correctly, I believe at one time SW had two X-pipe options; one with a "cheese grater" liner (presumably to address resonance) and one w/o. Personally, I opted for the clean 3" X-pipe (no such liner). Might be worth asking about if also purchasing the X-pipe - IF it is even offered anymore. Just sayin.
p.
Old 05-13-2013   #6
Schrade
HoLY cOw! yIKes!!! Finally hit that post # 58 after :54 minutes searching threads...
Originally Posted by Meanmyz View Post
Paul, I see that you have headers (without cats) and stock resonator and mufflers....
Anyone can chime in here:
With the '93 - '95 resonator and mufflers is it kind of an oxymoron to do a 500HP build with headers and hi flow cats and then be running through the stock resonator and mufflers?
From Marc H's information, it looks like the biggest restriction is at the inlet of the muffler. Also, in info on his site, it shows a general 5HP difference between 2nd generation stock and a freer flowing exhaust. I guess my question is...does that difference widen as you increase HP?
I am asking in assessing what I might do for mufflers.
Old 05-13-2013   #7
Franke
Schrade,
When i replaced the exhaust on my Z with the Corsa system I noticed that the inlet to the resonator in the middle of the car was only 1 5/8 inches for each side which then expanded back out on the outlet. I felt that it could be somewhat restrictive coming off the large cat converter pipe. But I,m not an expert on it. Maybe chevy had their reasons.
Old 05-13-2013   #8
Originally Posted by Franke View Post
Schrade,
they didn't think it through
Old 05-14-2013   #9
SteelBlueZR1
I think they just cheaped out on the design and used existing restrictive resonators from lesser Corvettes.
SteelBlueZR1 is offline   Reply With Quote
Old 05-14-2013   #10
That's why we're using Z06 exhaust control valves. No resonator but no drone either. Use an XPipe, and reduce weight.
