Old 08-07-2013   #1
tony dimambro
Default Full power light
Has anyone experienced the full power switch malfunctioning even though the full power light is on. If so how did you resolve it.
tony dimambro is offline   Reply With Quote
Old 08-07-2013   #2
scottfab
scottfab's Avatar
Default Re: Full power light
Not enough info. How is it you think the switch is malfunctioning?
What symptom(s). What year?
Scott
Old 08-07-2013   #3
tony dimambro
well the engine feels and sounds the same weather it's on or off and I believe the rpm's top are topping out under 7,000 so I think its not going in to full power. yr 1990
Old 08-07-2013   #4
efnfast
Tony, engine will only rev to about 5500 in normal mode.
efnfast is online now   Reply With Quote
Old 08-07-2013   #5
tony dimambro
Thank you so in neutral when not in full power rpm's max at 5500 do you know what they are in full mode
Old 08-08-2013   #6
Vette Guy
Vette Guy's Avatar
I had a similar problem.... stuck in a traffic jam for over an hour and a half in 108 degree head... power key was on, but no secondaries. I replaced the fuel pumps before I realized that the main vacuum line from the pump had collapsed into itself and sealed. Pull the line from the connector by the passenger water housing and check to ensure the pump runs.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 08-08-2013   #7
efnfast
5500 under load, i.e. driving. Rev limiter at 7250 rpm, and the engine should blast right to 7250.
Old 08-08-2013   #8
Mystic ZR-1
Mystic ZR-1's Avatar
"Thank you so in neutral when not in full power rpm's max at 5500 do you know what they are in full mod"
5500rpm in neutral???
Old 08-08-2013   #9
In Full Power 7200 not that I would like to test it.........
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-08-2013   #10
cvette98pacecar
This happened to me when I was having fun with a new Challenger. I was amazed that he was staying next to the Ruby until I hit around 6000 rpm and the engine was starving. Next go around I had the power key on, it was an entirely different story.
