View Poll Results: Which oil filter do you use?
AC Delco 69 27.27%
Amsoil 1 0.40%
Baldwin 0 0%
Bosch 68 26.88%
Fram 13 5.14%
K&N 13 5.14%
Mobil 1 54 21.34%
Napa 12 4.74%
Penske 0 0%
Pennzoil 1 0.40%
PowerFlo 1 0.40%
ProLine 0 0%
Purolator 3 1.19%
Quaker State 0 0%
STP 0 0%
Wix 18 7.11%
Voters: 253. You may not vote on this poll
Old 02-27-2013   #41
LancePearson
LancePearson's Avatar
Default Re: Which oil filter do you use?
I just bought two of the Napa 1324 Wix filters yesterday for my future oil changes. They looked them up and their data said they have the check valve as reported and a 16 pound bypass pressure. Most of the things I've bought from Napa are reasonable performers for the l48 1976's engine and now this one. Followed Marc's rec.
LancePearson is offline   Reply With Quote
Old 03-18-2013   #42
Schrade
Isn't this mill (LT5) bulletproof?
Seems that if you do the oil & filter change every 3k, or 3 months, whichever comes FIRST , then even a budget filter will get the job done... (unless the hammer stays on the floor for track use).
I owned a fleet for courier & delivery that I ran, and did the O/C about every 10 days for all of them, for many years, which was roughly, 3k, and all the vehicles kept a good squeeze under the heads. The last one, an Express 1-ton 5.7 bought new '02 as my own personal, had ZERO squeeze loss @ 205k...
Old 03-18-2013   #43
LancePearson
just out of curiosity when you reset the oil change on the dashboard, how many miles before it comes on saying to change? My 2008 TBSS calculates oil wear so it's not miles at all. How does this one work, straight miles or sensors inputs for varied use?
Manual did not say as far as I can tell.
Lance
Old 04-08-2013   #44
scottfab
scottfab's Avatar
Lance
3k miles.
Page 0B-2 Figure 1 Item # 1
Scott
Old 09-10-2014   #45
I use the AC PF970 with oil change every 2000 miles.
Old 11-04-2014   #46
Every 2000 miles on an oil change? Is that something you do once in the spring/start of the new driving season as a matter of routine, or ??? Just curious why the cadence is so high. Even in the DINO OIL days, 3000 miles was the norm, and that was with a 5 quart oil pan; including the filter. With full synthetic it is much higher - e.g., 5k and then some, depending on application.
Old 11-25-2014   #47
Paul,
The oil changes pretty much coincide w the driving season. I always change the oil for the winter. When I am getting ready for a long drive and/or racing situation as in going to BG, I change the oil prior to that event. The Castrol GTX I use is not SYNTH oil. I usually throw in 8-9 quarts/change w filter.
Old 11-19-2015   #48
"We also found that the NAPA 1324 filter retains eight ounces of oil after the engine is off for 24 hours. The filter is white in color and is made by WIX."
The above is from the H site oil filter recommendations page - Color is off but this is the one I use. Good price as well.
Old 12-05-2015   #49
I have been using the 1324 for a while now. Thing is sometimes we get a 1324 that doesn't hold oil in it overnight.
Old 05-08-2017   #50
msorenso
msorenso's Avatar
ACDELCO
Dr. Pete "Frankenstein's"
Ported and Polish combo
Cam retiming & Chip Tune
Corsa Exhaust No Cat
SW Stainless Long Tube Headers
MSD Coils
DRM Coil Overs
Hurst Shifter
ZF Doc Beam Plates
Center Force Dual Friction
msorenso is offline   Reply With Quote
