Old 03-16-2018   #1
ssrszz4
Default Intake gasket sets?
Which do you use the 1/32" or 3/32"?
Sent from my XT1585 using Tapatalk
ssrszz4 is offline   Reply With Quote
Old 03-16-2018   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Intake gasket sets?
I prefer Jerry’s thicker 3/64” plenum gaskets.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-16-2018   #3
MuRCieLaGo
I suggest you buy a couple of pairs at a time.
I've owned the car for 3 years/5,000 miles and I bought my 4th & 5th pairs wednesday.
Old 03-16-2018   #4
I use the thinner Plenum Gaskets 1/32" and I have TB Coolant Blocked at Injector Housing on ALL ZR-1s
Old 03-18-2018   #5
Ozruss90
Ozruss90's Avatar
Could someone please explain why there are different thickness gaskets available? Does it depend on the year model, that they are a different thickness???
Cheers🇦🇺
Ozruss90 is offline   Reply With Quote
Old 03-18-2018   #6
MuRCieLaGo
No.
From what I understood, the only advantage of 3/64'' is that they may be re-usable after a plenum removal, compared to 1/32''.
Old 03-18-2018   #7
Ozruss90
Ozruss90's Avatar
Thanks for clearing that up. When the time comes that l need to order, l now know l don’t need to order a specific thickness gasket set.
Old 03-19-2018   #8
Wigert
Sorry if I am hijacking the thread but on this topic I was wondering if someone of you could till me if the plenum gasket is enough or if an additional sealant is needed? When I had my car at the shop last year the mechanic also put some red sealant in addition to the gasket... I am not sure what that was...
Skickat från min GEM-701L via Tapatalk
Wigert is offline   Reply With Quote
Old 03-19-2018   #9
I have Throttle Body Coolant blocked at Injector Housings and do not use anything on 1/32 Plenum Gaskets.
Set Plenum in Place making ALL electrical and vacuum connections and then slide gaskets in place (lift Plenum just enough to slide gaskets in place).
I tighten Plenum SS Allen Head Bolts tight but not too tight and then check them once in a while (less than what book calls for as I have no coolant to TB)
Old 03-20-2018   #10
Wigert
Thanks for the input Dynomite!
