Old 03-23-2011   #1
Default Raptor Shift light impressions Single Vs Dual Mode
I had the ZFDOC install a Raptor Dual mode shift light last week. Works great but I wanted to let the community know the "dual mode" light might change your plans for installation. I chose amber BTW. The original plan was to have it installed behind the center vent like so many folks have already have done (Andrew most recently). The problem is once you do that you wont have the option of hitting the mode bottom that switches you inbetween modes or the normal shift mode and the staging mode. You would have to remove the vent in order to do this. The button is almost all the way on the bottom due to the setting dip switches residing in the middle of the shift light
Heres where Andrew installed his but I didnt due to the button. BTW Andrew did a nice clean install on his single mode light
I guess your install plans would still be ok if you chose to ignore this other function so keep this in mind when you purchase one. The single mode version which is about $40 cheaper will work great but it doesnt have the staging mode option. I just placed it next to the left pillar and its not bad. I will post up a pic of that later tonight. Raptor seems to be the WTG since Dom determined a timing issue with the Harlan setup. It is a very small and slick little mod. Just FYI GC
