Old 12-16-2017   #1
Ccmano
Default Power steering issue
This is giving me fits...
Replaced the high pressure and supply (reservoir to pump) hoses due to fluid leaks. Bled the system per the manual twice now. For the life of me I can’t get the air out of the system. If anything it seams to be sucking in more air. I removed and double checked the new supply hose and changed out the clamps to wider ones. If figure if it’s pulling air it gas to be from the supply side. The high pressure side is tight with no fluid leaks. I can’t imagine it can pull air from the high pressure side, or am I wrong?
Anyone ever see anything like this?
H
