Old 12-04-2019   #1
whale
Default Vaccum solenoid switch
OK where do i get one of these......does the local auto parts store have them?
whale is offline   Reply With Quote
Old 12-04-2019   #2
Default Re: Vaccum solenoid switch
Check with Jerry @ Jerry's Gaskets.com is where I'd look first!
Old 12-04-2019   #3
Young1
Young1's Avatar
AC Delco 214-358. Amazon or Rock Auto. I am waiting on one from Amazon right now to install this weekend. You do have to cut a spline out of the connector port and swap the bracket. The originals are no longer available.
Steve Young
Second Owner
SOLD
SOLD
Old 12-04-2019   #4
There are 2 types of the solenoid valves,the early type takes a small square foam filter and the later design takes a cylinder type filter. Does anybody know what type of filter this 214-358 takes,looks like the early design.
Old 12-05-2019   #5
Maybe four Solenoid Valves?
Vacuum Solenoid for early (90' under Plenum).
Vacuum Solenoid (filter) for Later (95' under Plenum)................Solenoid for Charcoal Canister (91'-95' under Plenum).
Solenoid located on Charcoal Canister (not shown) under Drivers Headlight (90').
Old 12-05-2019   #6
Young1
Young1's Avatar
214-358 has the square thin filter. The spring steel filter cover snaps on to either the early or late LT5 bracket. Easy peasy. I am doing a 93 MY right now. Test your replacement solenoid before install. I had a bad one that the plastic was malformed inside the nipples.
Steve Young
Second Owner
SOLD
SOLD
Old 12-05-2019   #7
whale
Thanks guys!!
Old 12-05-2019   #8
The filter for the switch is $13.00. This is for a piece of foam that is maybe 1/8 in thick and is 5/8 by 3/4 of an inch. When I went to the dealer to buy the cylinder shaped filter the parts guy ordered this one instead. I thought it was so absurd to charge $13.00 for such a small piece of foam I paid for it and kept it,shows how smart I am.
Old 12-07-2019   #9
whale
Just wondering......the OEM part has 3 vacuum ports and the replacement has 3 ports.....how do you make it work?
Old 12-07-2019   #10
The second switch with the silver nipple is the later design that takes the slip on filter.
