Old 06-04-2007   #1
va beach biker
va beach biker's Avatar
Default Resonator or not?
I'm getting ready to put a B&B cat-back on, and I've seen some guys not running the resonator (with various systems). Any pros or cons? It wouldn't be with an X pipe in it's place, just straight pipes from the transmission back to the mufflers.
va beach biker is offline   Reply With Quote
Old 06-04-2007   #2
Z Factor
Z Factor's Avatar
Lightbulb Re: Resonator or not?
Without a resonator you will have increased cabin noise. However by eliminating it you should see a slight HP increase. I put an X-pipe on my B&B to help equalize pressure and create better scavenging. However the resonance can drive some people nuts during slow city driving, so you may want to hear how loud your system will be without it.
I have headers, no cats, x-pipe and the B&B. Ive gotten use to it and rarely drive at RPM's that will produce heavy resonance.
Old 06-04-2007   #3
jonszr1
jonszr1's Avatar
Default Re: Resonator or not?
I ended up with what I think is the best of both worlds a muffler/resonator thats an xpipe. the car is quiet and has the hpto boot . the part i am talking about is onpg 66 of the summit catalog in the center at the top made by dyno max ck it out was my answer to quiet power
Old 06-05-2007   #4
blackjack
i replaced the resonator with an x-pipe...since i kept the cats,the difference in noise and resonnance is hardly noticeable,as the cats absorb much of the noise
blackjack
Old 06-05-2007   #5
jonszr1
jonszr1's Avatar
when you add headers is when ths problem begins even with cats its drone time with an xpipe
Old 06-05-2007   #6
zr-1assassin
zr-1assassin's Avatar
i cut out the resonator and ran strait pipes to the mufflers, i think it sounds even better! you got to have a little rummmmmble to it. not bad on the noise at all, go for it!
zr-1assassin is offline   Reply With Quote
Old 06-05-2007   #7
zrss
I'm running the B&B with an X pipe behind a 415 with headers and no cats. It's a little loud inside, except for 1000 rpm where the resonance is terrible. The sound outside the car is wonderful.
zrss is offline   Reply With Quote
Old 06-05-2007   #8
zr-1assassin
i dont know about you all but i rarely see the 1000rpm range and sometimes i use the resonance when i am beside a mustang or something and i want them to FEEL the growl
Old 06-06-2007   #9
va beach biker
Done. Just came back from the shop. They didn't have the stuff on hand to do the X pipe, so that can wait until it's header time. Just straight pipes from the cats on back. Sounds really good. The interior resonance isn't too bad - or maybe my SS Camaro just had me conditioned to that kind of noise.
Old 06-06-2007   #10
zr-1assassin
well, what mufflers did you finaly decide on?
