Old 03-24-2011   #11
Default Re: Raptor Shift light impressions Single Vs Dual Mode
I installed mine on the A-pillar also. I wired mine into the parking lights on the head light switch. When i want it on, turn on the parking lights, otherwise, leave it off.
Jerry that looks good. Whats the other gauge?
Old 03-24-2011   #12
Direct reading, mechanical oil pressure.
Old 03-24-2011   #13
Scrrem
Scrrem's Avatar
Just great you guys........another thing I need to buy.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-24-2011   #14
Yep, that's where I mounted the shift light also.
Old 03-24-2011   #15
Rich
You love it....
Old 03-24-2011   #16
Nothing like being double sure
Old 03-25-2011   #17
With electronic oil pressure senders like the LT5 has, that have been known to fail, I feel more comfortable knowing that there's nothing between the gauge & pressure. What do you do if either one of the oil pressure senders fails & you're on the road when you show 0 psi or the warning light illuminates? Just old school I guess.......
Old 03-25-2011   #18
Pillar Pod: Ecklers PN 38220 $28.99
Autometer Oil Pressure Guage: Summit PN ATM-2604 $37.95
Old 03-25-2011   #19
sammy
jerry did you just t into where the top oil pressure sensor is ?
Old 03-25-2011   #20
Correct. To keep the height low, I found a brass tee & a brass "close" (all thread) pipe nipple. Wrap the threads with teflon tape. Use caution when tightening as the teflon tape really makes it easy to overtighten.
